from asa not able to ping ISP edge router(hence not able to use ip SLA)
Sipl_24034
AS we are using firewall .our link is up and working fine  but we  are not able to ping aur edge router beacause of that we are not able to use IP sla. basicly ip sla use icmp to ping  edge router
kindly help regarding same
16 Replies 16
i found  while traceroute from edge taking unusal path. escalated to isp .
i will come back after isp responce ...
Try to ping the ASA ip from edge router and take capture on ASA as suggested by Akshay earlier, this would help in figuring out if there are correct routes configured in your network to forward traffic to ASA from edge router.
I think the problem lies outside ASA.
Share your findings.
Rishabh
