FTD block traffic in same VLAN
khld.saad
Level 2
Level 2
I have Ftd  but still in test environment as  we have try to get it on production two times but it fail because it blocks the traffic in the  same vlan i know its wired but that what happened the hosted in same vlan is blocked a cant even ping its always say ping translate fail . I have upgraded to 6.2.3  and the same issues exist ..
any help to solve it
17 Replies 17
00:24:51 Cisco Systems, Inc >>>> is a layer two Switch has Vlan interface with IP 192.168.0.9
38:90:A5 Cisco Systems, Inc>>>>>  the FTD  and its have a sub interface with 192.168.0.254
there is no duplicaion in IPs
but always the FTD do this issuse and that why the traffic is blocked in Layer 2 .
this scenario   was a going to be a production but after a lot of failure  downtime its become a lab to test and insure that will run in production with no issues.
I recommend opening a TAC case spo the engineer can work with you in real time.
it was miss config in nat command that turn the Device as proxy arp
