FTD connection limits per client
matteodapozzo
Level 3
Level 3
Does anybody know if FTD supports (maybe through FlexConfig) the following ASA equivalent for limit connection on a single IP ? set connection per-client-max XXXXXX (through class-map - MPF)
CLI reference:
set connection {[conn-max n ] [embryonic-conn-max n ] [ per-client-embryonic-max n ] [ per-client-max n ] [random-sequence-number { enable | disable }]}
Matteo
