FTD/F Help confirming rule(s) or policies are allowing traffic in
CiscoBrownBelt
Level 6
Level 6
Take a look at packet-tracer below. I have scrubbed some IPs and names for simplicity and privacy. Are you able to confirm based on the output which rule is allowing the 1.1.1.1 traffic to 2.2.2.2 in through the Outside interface? Basically trying to clean up rules as too many zero hit rules and ANY type rules.
> packet-tracer input Outside tcp 1.1.1.1 8305 2.2.2.2443 detailed
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
 Forward Flow based lookup yields rule:
 in  id=0x55a70ce150, priority=13, domain=capture, deny=false
        hits=64174149, user_data=0x5575ed3ae0, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
        input_ifc=Outside, output_ifc=any
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
 in  id=0x55a7011190, priority=1, domain=permit, deny=false
        hits=2663353715, user_data=0x0, cs_id=0x0, l3_type=0x8
        dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 3
Type: INPUT-ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Found next-hop 3.3.3.3 using egress ifc  Outside(vrfid:0)
Phase: 4
Type: ECMP load balancing
Subtype:
Result: ALLOW
Config:
ECMP load balancing
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group CSM_FW_ACL_ global
access-list CSM_FW_ACL_ advanced permit ip any any rule-id 268441600
access-list CSM_FW_ACL_ remark rule-id 268441600: ACCESS POLICY: EntEdge-FTD2140-Local-Sensor_ACP - Mandatory
access-list CSM_FW_ACL_ remark rule-id 268441600: L7 RULE: MyRule test
 This packet will be sent to snort for additional processing where a verdict will be reached
 in  id=0xffb4046d30, priority=12, domain=permit, deny=false
        hits=19477110, user_data=0x5586141700, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=any
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=any, vlan=0, dscp=0x0, nsg_id=none
        input_ifc=any, output_ifc=any
Phase: 6
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
 match any
policy-map global_policy
 class class-default
  set connection advanced-options UM_STATIC_TCP_MAP
service-policy global_policy global
 in  id=0xffc05e2e00, priority=7, domain=conn-set, deny=false
        hits=5016061, user_data=0xffc05e0b40, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0, nsg_id=none
        input_ifc=Outside(vrfid:0), output_ifc=any
Phase: 7
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0x55a2434a70, priority=0, domain=nat-per-session, deny=false
        hits=29139365, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x55a7017410, priority=0, domain=inspect-ip-options, deny=true
        hits=22780334, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 9
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
 in  id=0xffc007d910, priority=13, domain=ipsec-tunnel-flow, deny=true
        hits=4590121, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 10
Type: NAT
Result: ALLOW
Config:
 Reverse Flow based lookup yields rule:
        hits=29139367, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 11
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
        hits=22780336, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 12
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 25829692, packet dispatched to next module
Module information for forward flow ...
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_tcp_proxy
snp_fp_snort
snp_fp_tcp_proxy
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Module information for reverse flow ...
snp_fp_translate
snp_fp_tcp_proxy
snp_fp_snort
snp_fp_tcp_proxy
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 13
Type: EXTERNAL-INSPECT
Subtype:
Result: ALLOW
Config:
Application: 'SNORT Inspect'
Phase: 14
Type: SNORT
Subtype:
Result: ALLOW
Config:
Snort Trace:
Firewall: starting AC rule matching, zone 4 -> 4, geo 0 -> 0, vlan 0, sgt 0, src sgt type 0, dest_sgt_tag 0, dest sgt type 0, user 9999997, icmpType 113, icmpCode 187
Packet: TCP, SYN, seq 1720790805
Session: new snort session
AppID: service unknown (0), application unknown (0)
Firewall: starting AC rule matching, zone 4 -> 4, geo 0 -> 0, vlan 0, sgt 0, src sgt type 0, dest_sgt_tag 0, dest sgt type 0, user 9999997, icmpType 0, icmpCode 0
Firewall: pending rule-matching, id 268441600, pending URL
Snort id 11, NAP id 1, IPS id 0, Verdict PASS
Snort Verdict: (pass-packet) allow this packet
Phase: 15
Type: INPUT-ROUTE-LOOKUP-FROM-OUTPUT-ROUTE-LOOKUP
Subtype: Resolve Preferred Egress interface
Result: ALLOW
Config:
Phase: 16
Type: ADJACENCY-LOOKUP
Subtype: Resolve Nexthop IP address to MAC
Result: ALLOW
Config:
Found adjacency entry for Next-hop 3.3.3.3 on interface  Outside
Adjacency :Active
MAC address 2416.9daa.57bf hits 1359893055 reference 273
Result:
input-interface: Outside(vrfid:0)
input-status: up
input-line-status: up
output-interface: Outside(vrfid:0)
output-status: up
output-line-status: up
Action: allow
17 Replies 17
each phase in traffic flow in SNORT  is check by specific command.
there is no one magic command cover all phases in traffic flow.
but you can use
Snort Verdict: allow/deny to go directly to which SNORT phase drop the traffic
If you are not finding the rule in the ACP, have you checked the prefilter rule associated with the ACP? it might be matching there.
Please remember to select a correct answer and rate helpful posts
Yes I have. I believe Gustavo has answered what is happening. What i have been trying to do is actually confirm the rule as pre-filers and ACP always don't show hits when trying modify/optimize rules.
