FTD NAT Issue on UDP port 500
ahmad82pkn
Level 3
Level 3
Hi Team.
I have a host on LAN that is trying to build IPSEC VPN with remote site.
I am using Dynamic PAT for all traffic.
I believe it should work.
But interestingly, I see all traffic getting NAT but not UDP 500.
Any idea why? Ideally i want UDP 500 and 4500 to NAT as well.
Packet Tracer for random UDP port 400 shows NAT happening, but port 500 shows not.
> show conn | include 172.18.6.
UDP Guest 172.18.6.11:500 outside 54.226.109.1:500, idle 0:00:08, bytes 899668, flags - N1
NOT Triggering any NAT example
> packet-tracer input Guest udp 172.18.6.11 500 54.226.109.1 500 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Elapsed time: 34140 ns
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in id=0xffb8216890, priority=1, domain=permit, deny=false
hits=21273705388, user_data=0x0, cs_id=0x0, l3_type=0x8
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0100.0000.0000
input_ifc=Guest, output_ifc=any
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Elapsed time: 8535 ns
Config:
Found flow with id 511784475, using existing flow
Module information for forward flow ...
snp_fp_inspect_ip_options
snp_fp_snort
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_translate
snp_fp_snort
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Phase: 3
Type: SNORT
Subtype:
Result: ALLOW
Elapsed time: 9104 ns
Config:
Snort Verdict: (fast-forward) fast forward this flow
Result:
input-interface: Guest(vrfid:0)
input-status: up
input-line-status: up
Action: allow
Time Taken: 51779 ns
NAT Seems working on RANDOM UDP Ports others than 500
> packet-tracer input Guest udp 172.18.6.11 400 54.226.109.1 400 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Elapsed time: 19915 ns
Config:
Implicit Rule
hits=21273715225, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 2
Type: INPUT-ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Elapsed time: 23898 ns
Config:
Found next-hop 50.225.18.1 using egress ifc outside(vrfid:0)
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Elapsed time: 6828 ns
Config:
access-group ACL_ global
access-list ACL_ advanced permit ip any any rule-id 268459024
access-list ACL_ remark rule-id 268459024: ACCESS POLICY: Guest - Mandatory
access-list ACL_ remark rule-id 268459024: L7 RULE: Block_Torrent
This packet will be sent to snort for additional processing where a verdict will be reached
in id=0xffc069ea80, priority=12, domain=permit, deny=false
hits=66398194, user_data=0x55877bb780, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=any
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=any, vlan=0, dscp=0x0, nsg_id=none
input_ifc=any, output_ifc=any
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
match any
policy-map global_policy
class class-default
set connection advanced-options UM_STATIC_TCP_MAP
service-policy global_policy global
in id=0xffe06465f0, priority=7, domain=conn-set, deny=false
hits=424743281, user_data=0xffe063d220, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0, nsg_id=none
input_ifc=Guest(vrfid:0), output_ifc=any
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (Guest,outside) source dynamic Guest_Subnet interface
Dynamic translate 172.18.6.11/400 to 50.225.18.158/58959
in id=0xffe423ee70, priority=6, domain=nat, deny=false
hits=3781633, user_data=0x559fb853b0, cs_id=0x0, flags=0x0, protocol=0
src ip/id=172.18.0.0, mask=255.255.0.0, port=0, tag=any
input_ifc=Guest(vrfid:0), output_ifc=outside(vrfid:0)
Phase: 6
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
in id=0x55a30f7fa0, priority=0, domain=nat-per-session, deny=true
hits=423356137, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0xffb821cb40, priority=0, domain=inspect-ip-options, deny=true
hits=432490956, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: NAT
Subtype: rpf-check
Result: ALLOW
Elapsed time: 35278 ns
Config:
out id=0xffe423fb60, priority=6, domain=nat-reverse, deny=false
hits=1718262, user_data=0x559e514bc0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 9
Type: NAT
Result: ALLOW
Elapsed time: 38692 ns
Config:
Reverse Flow based lookup yields rule:
hits=423356139, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Elapsed time: 1138 ns
Config:
in id=0xffc441f5b0, priority=0, domain=inspect-ip-options, deny=true
hits=584189667, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
input_ifc=outside(vrfid:0), output_ifc=any
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Elapsed time: 38123 ns
Config:
New flow created with id 512380988, packet dispatched to next module
snp_fp_snort
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
snp_fp_translate
snp_fp_snort
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 12
Type: EXTERNAL-INSPECT
Subtype:
Result: ALLOW
Elapsed time: 9673 ns
Config:
Application: 'SNORT Inspect'
Phase: 13
Type: SNORT
Subtype:
Result: ALLOW
Elapsed time: 137129 ns
Config:
Snort Trace:
Firewall: starting AC rule matching, zone 9 -> 9, geo 0 -> 0, vlan 0, sgt 0, src sgt type 0, dest_sgt_tag 0, dest sgt type 0, user 9999997, icmpType 61, icmpCode 13
Firewall: starting AC rule matching, zone 9 -> 9, geo 0 -> 0, vlan 0, sgt 0, src sgt type 0, dest_sgt_tag 0, dest sgt type 0, user 9999997, icmpType 138, icmpCode 109
Firewall: starting AC rule matching, zone 9 -> 9, geo 0 -> 0, vlan 0, sgt 0, src sgt type 0, dest_sgt_tag 0, dest sgt type 0, user 9999997, icmpType 42, icmpCode 38
Packet: UDP
Session: new snort session
AppID: service unknown (0), application unknown (0)
Firewall: starting AC rule matching, zone 7 -> 9, geo 0 -> 0, vlan 0, sgt 0, src sgt type 0, dest_sgt_tag 0, dest sgt type 0, user 9999997, icmpType 0, icmpCode 0
Firewall: pending rule-matching, id 268459024, pending AppID
Snort id 3, NAP id 2, IPS id 0, Verdict PASS, Blocked by SSL
Snort Verdict: (pass-packet) allow this packet
Phase: 14
Type: ECMP load balancing
Subtype:
Result: ALLOW
Config:
ECMP load balancing
Phase: 15
Type: ADJACENCY-LOOKUP
Subtype: Resolve Nexthop IP address to MAC
Result: ALLOW
Elapsed time: 3414 ns
Config:
Found adjacency entry for Next-hop 50.225.18.1 on interface outside
Adjacency :Active
MAC address e85c.0a7d.5084 hits 2663213 reference 383
Result:
input-status: up
output-interface: outside(vrfid:0)
output-status: up
output-line-status: up
Action: allow
Time Taken: 349935 ns
17 Replies 17
yes most likely.. NAT will work no matter what... but nat traversal will not be used. so IKE negotiation will go through and
then ipsec ESP will try to get transmitted and FTD will drop as by default it doesnt allow ipsec pass-through.. ASA has the command.. ftd may have to do with flexconfig..
regardless, yes make sure nat-traversal and run debugs on both sides and see where does it fail...
Also, implement pre-filter on FTD for best performance.
Aina William
It looks like the problem you're having is with UDP port 500 not being NATed. This can happen if NAT Traversal (NAT-T) is not being set off. IPsec data is usually wrapped in UDP 4500 by NAT-T so that it can get through NAT devices. Because you're using Dynamic PAT, UDP 500 is probably not being blocked by NAT. This is because it's often used for ISAKMP data, which may be handled differently because of security rules. To fix this, make sure that NAT-T is turned on in your VPN settings. This will wrap the traffic in UDP 4500 and let it be NATed properly. Also, make sure that your firewall rules and NAT settings clearly allow NAT for both UDP 500 and 4500.
ahmad82pkn
Level 3
Level 3
Issue is resolved after enabling NAT-T on SRX
Updating local identity and remote identity
local identity Egress public IP of FTD
remote identity public IP of remote peer
Also SRX Egress interface had IKE system service enabled on untrust zone. But then on interface level it didnt have ike enabled. Which overrides IKE setting enabled on unturst zone level.
Adding ike under interface level was last nail that fixed the issue along with above changes.
security-zone untrust {
screen untrust-screen;
host-inbound-traffic {
system-services {
ike;
interfaces {
ge-0/0/0.0 {
system-services {
ike;
dhcp;
tftp;
https;
