FWSM issue : Support Maximum Speed
johnyoon75
Level 5
Level 5
Hi all,
I have a question about supportting maximum speed on FWSM.
Cat6500, which contained FWSM on the chassis, connect to internet over 300Mbps bandwidth.
When i connect laptop using 1Gbps Lancard to test innternet speed from outside interface of FWSM, I can see the speed over the 200Mbps, but when i test from inside of fwsm the same way, i just can see only under 100Mbps speed.
I'm curious about this..
Does anyone have the same experience??
regards,
john.
Patrick Iseli
Level 11
Level 11
Have you checked the Duplex settings ?
sincerely
Patrick
hi patrick,
sure, i've already configured the port setting.
regards,
john.
How are you measuring the speed. If you are using java plugins like dsl reports they may not be accurate specially with nat/ASA/randomsequnces of the fw.
