FWSM Module Power Down
Our FWSM module went down today. After enable the power and reset the module, It is again working fine.
Here are some logs and diagnostic tests are attached:
Before Reset:
Dec 14  06:50:20.072 KSA: %SNMP-5-MODULETRAP: Module 6 [Down] Trap
Dec 14  06:50:20.068 KSA: SP: The PC in slot 6 is shutting down. Please wait  ...
Dec 14  06:50:35.080 KSA: SP: shutdown_pc_process:No response from module  6
Dec 14  06:50:36.088 KSA: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off  (Reset)
Dec 14  06:52:16.964 KSA: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal  Diagnostics...
Dec 14  06:52:18.980 KSA: %SNMP-5-MODULETRAP: Module 6 [Up] Trap
Dec 14  06:52:18.980 KSA: %SVCLC-5-FWVTPMODE: VTP mode is set to  non-transparent
Dec 14  06:52:19.020 KSA: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been  disabled.
Dec 14  06:52:19.868 KSA: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online  Diagnostics
Dec 14  06:52:33.048 KSA: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now  online
Dec 14  06:54:18.564 KSA: %SNMP-5-MODULETRAP: Module 6 [Down] Trap
Dec 14  06:54:18.564 KSA: SP: The PC in slot 6 is shutting down. Please wait  ...
Dec 14  06:54:33.576 KSA: SP: shutdown_pc_process:No response from module  6
Dec 14  06:54:34.588 KSA: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off  (Reset)
Dec 14  07:03:23.984 KSA: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off  (Module  Failed SCP dnld)
SWITCH#sh  module power
6   Firewall Module                        on            off  (Module  Failed SCP  dnld)
SWITCH#sh  module
Mod  MAC          addresses                       Hw    Fw           Sw                  Status
6       XXXXXXXXX to XXXXXXXXXXX               3.0   7.2(1)       8.5(0.46)RFW   PwrDown
After Reset:
Dec 14  08:49:39.228 KSA: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal  Diagnostics...
Dec 14  08:49:41.248 KSA: %SNMP-5-MODULETRAP: Module 6 [Up] Trap
Dec 14  08:49:41.248 KSA: %SVCLC-5-FWVTPMODE: VTP mode is set to  non-transparent
Dec 14  08:49:41.284 KSA: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been  disabled.
Dec 14  08:49:42.188 KSA: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online  Diagnostics
Dec 14  08:49:53.932 KSA: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are  now online
SWITCH#sh  module
   6      XXXXXXXXXX to XXXXXXXXXXX             3.0   7.2(1)       3.1(4)           Ok
I want to know the reason behind this module power down.
We have Cisco 6513 with IOS Version 12.2(18)SXF17
Anser
Kureli Sankar
All line cards are required to answer SCP (serial control protocol) pings over the eobc (ethernet out of band channel).  When line card fails to
answer SCP ( due to high CPU, mis-seated line cards or hardware failure issues) the supervisor will reload that line card in an attempt to recover
it.  When the line card (in this case an FWSM) is reloaded by the sup, you will see these messages in the switches logs.
Pls. reseat the module and if the problem continues pls. open a TAC case to get the card replaced.
-KS
