Help/ayuda
grupovelasco
Community Member
We have an ASA5020 Firewall
* Need to obtain the latest  version of software to manage the ASA 5020, and we have the version 5, but we do  not work with Windows 7.
* On the other hand we want to mount the access  VPN, and we know that we need to install software on the client (windows), and  the cost for each license. In addition to some manual configuration and the  software where you can get.
Jennifer Halim
What version of ASA software are you running? I can advise you on the corresponding ASDM version which is supported based on your ASA software version.
You can run IPSec VPN Client at no extra cost.
Here is the sample configuration for your reference:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
