help, error connection Cisco Identity Services Engine with AD, global catalog port status error
JERRI -
Dear all,
I have Cisco Indentity Services Engine, that  connected to Active Directory. When I test connection detailed,
the result is error, said:
Test Connection Results
This dialog shows the detailed logs for the operation for: idsv0018.
Status: FAILED: Global Catalog port status error.
Can anyone help?
I believe,  because this error, I can't search group of AD, at Cisco ISE.
FYI: the connection from Cisco ISE to AD, joined with successful result.
Jerri
Jatin Katyal
It's clears that when ISE tries to  find the GC using the _gc._tcp. DNS query. It doesn't find that  information on the Domain controller. The GC information is missing on  the DC.
_
gc._tcp.DnsForestName
Allows a client to locate a Global Catalog (gc) server for this domain.
Jatin Katyal
- Do rate helpful posts -
~Jatin
