Help on ASA traffic Outside
saquib.tandel
Hello
Different application needs different ports to pass traffic from inside to outside with ASA placed inbetween.
Instead of allowing all ports ; how to streamline with needed ports. Struggling to get it working.
LANUSERS_____switch____ASA_____INTERNET
Access-list is applied on ASA inside interface.
IF I start a Trading application from a LAN Host which needs to connect to Trading Server on INTERNET; how do I identify which ports are needed to open on ASA??
cisco24x7
Level 6
Level 6
access-list capture permit ip LAN_host Internet_host log
capture tcpdump access-list test interface internal
"show capture tcpdump" will show you which port LAN_host communicate with Internet host.
I am aware of LAN Host but not aware of Internet Host.
How to clear counter of the log as it shows already some hits
