Help to create flexconfig to reset interface or reboot fp1010
I have my Firewall set as my outside device. It is using dhcp from my ISP Verizon to get its public ip. The problem is Verizon changes the ip and the firepower doesn't retry the Dora process to get another IP. Is there a way to create a flex config to monitor the status of the interface and if no ip is detected either shut/no shut, reset, or reboot the device?
balaji.bandi
Never tried it, but looks possible -  but needs to test.  ( not all flexconfig work in FTD, most of them blocked )
https://www.cisco.com/c/en/us/td/docs/security/firepower/650/configuration/guide/fpmc-config-guide-v65/flexconfig_policies.html?bookSearch=true
BB
