Help with Cisco PIX 515E
tbrinkma
I want my Remote Access VPN to work to our new PIX firewall Cisco PIX 515E. With AAA to a radius server.
I want the Cisco VPN client to come with a popup which in I can fill in my details coming from the radius server.
I configured the AAA server by hand a run the VPN wizard in ASDM.
After I done this I can't log in with the client.
I think it has something to do with the vpngroup commando but the wizard didn't create anything for this.
Can somebody help me checking the config and see if anything need to be modified?
pixfirewall# sh run
: Saved
PIX Version 7.2(2)
hostname pixfirewall
domain-name default.domain.invalid
enable password xxxxxxxxxxxx encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address [External IP]
interface Ethernet1
nameif inside
security-level 100
ip address 10.1.1.7 255.255.0.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd xxx
ftp mode passive
dns server-group DefaultDNS
access-list inside_nat0_outbound extended permit ip any 10.248.2.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool ClientPool 10.248.2.0-10.248.2.255 mask 255.255.0.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server vpn protocol radius
aaa-server vpn host [Radius server]
key [Radius secret]
group-policy [Name] internal
group-policy [Name] attributes
dns-server value 10.1.3.100 10.1.3.101
vpn-tunnel-protocol IPSec
default-domain value intranet.[Name].nl
http server enable
http 10.1.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication crack
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group [Name] type ipsec-ra
tunnel-group [Name] general-attributes
address-pool ClientPool
authentication-server-group vpn
default-group-policy [Name]
telnet 10.0.0.0 255.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.1.1.8-10.1.2.7 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
16 Replies 16
Yes.
According to your configuration:
ip local pool Clientpool 10.248.2.0-10.248.2.255 mask 255.255.255.0
HTH,
Paulo
Did put the following lines in it:
access-list outside_cryptomap_dyn_20 permit ip any 10.248.2.0 255.255.255.0
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
Still nothing...
