hosting solution engine 1.8.2
j.nielsen
Community Member
I am running a HSE 1.8.2 and have a problem in creating a ROLE with only Monitoring access to see status of services?
In version 1.7.2 it was possible to create a user with the role HOSTING (this user then only had monitoring access to see status of services at e.g. CSS)
How do i create such a user ?
rlcarr
Level 5
Level 5
You may have better luck if you post this question in the "Content Networking" section under Emerging Technologies.
I'm not aware of anybody using HSE for VPN management.
