How do I get traceroutes to work through ASA?
Andy White
Level 3
Level 3
We have a number of networks that go though our ASA, but we have never been able to run a traceroute even though we have ICMP any any running on each inerface.  When we try a tracert from a Windows PC to a remote destination like google it works, but if we try a trace through one of the subinterfaces off the ASA (DMZ) it doesn't work.
For example I try and trace a router on our WAN and it goes to our LAN switch which then forwards to the ASA and then it his a wall:
C:\Users\me>tracert 172.30.2.1 (remote WAN router)
Tracing route to 172.30.2.1 over a maximum of 30 hop
  1    <1 ms    <1 ms    <1 ms  192.168.90.254 (my gateway, whichis our core LAN switch)
  2     *             *        *     Request timed out.
I've never been able to solve this, any ideas?
16 Replies 16
I read that using icmp fixup and icmp fixup error has worked, is this included under the default icmp inspect as I can't find this?
The below configuration commands
fixup protocol icmp
fixup protocol icmp error
are the old command format which is still supported but in newer software they will be converted to
inspect icmp
inspect icmp error
which were already in your configuration
- Jouni
