How to config Max LSA for OSPF in Cisco ASA ?
danilopasiani1
I need to config max LSA for OSPF in Cisco ASA and I would like to know How to config Max LSA for OSPF in Cisco ASA5585-SSP-10 ?
Cisco Adaptive Security Appliance Software Version 9.6(2)13
Device Manager Version 7.6(2)150
The current config is "Max LSA-Unlimited".
Hi @danilopasiani1
This command does not exist in the handle yet.
I just confirmed https://quickview.cloudapps.cisco.com/quickview/bug/CSCuy77362
if my answer was helpful to you, check it out as helpful so others can be helped.
Best Regards,
Josiane
Twitter: SecureGirlNinja
HI @danilopasiani1
Commands needed
https://www.cisco.com/c/m/en_us/techdoc/dc/reference/cli/nxos/commands/ospf-old/max-metric-router-lsa-ospf.html
If the commands are not available, it may be related to the Bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy77362/?rfs=iqvred
Best Regards
Josiane
Twitter:SecureGirlNinja
Hi Josiane,
Maybe this function doesn't exist for Cisco ASA.
I couldn't find the max-metric command on Cisco Asa so I asked for help on the forum.
Thanks for help.
Hi @danilopasiani1
Best Regards,
Josiane
