HTTP and PDM problem on Pix 520 firewall
joseph_samaha
Community Member
I have a pix 520 firewall(6.1(4) ver), pdm and http are enabled, i just can't access the pix through HTTP( http://ipaddress) neither the pdm (https://ipaddress),having the the knowledge that i have a pix 515 working fine with pdm and http), is there any workaround?
B Regards
Joseph
dnatale
Community Member
I've had a similiar problem. Open your browser, go to --> Tools --> Internet Options, --> Connections --> LAN Settings. There you must disable the option "use a proxy server". Confirm with ok then enter your Firewalls IP in the
address field (https://xxx.xxx.xxx.xxx)
The passwort is your enable password.
I hope this hint could solve your problem.
Dario
mostiguy
Level 11
Level 11
what does a "show http" do?
you need to see:
http server enabled
and netblocks that are allowed to connect to it, and the interfaces which they are on:
192.168.0.0 255.255.255.0 inside
