ICMP Problem whilst using PAT on Pix
g.watt
I currently have PAT enabled on our Pix, I can connect to the Net however whenever I try to ping I can see the ICMP packets getting dropped on the way back in. I have a default rule permitting IP outbound from any internal address. My understanding is that the session should keep a port open whilst I am initiating the ping. My only thoughts are that the ping is getting dropped because the Pix is seeing this as a session, which is being initiated from the remote site. Can anyone offer an explanation to this?
Patrick Iseli
Level 7
Level 7
ICMP is not a stateful protocol !
Thats why even from the inside network with PAT,NAT and no access-list on the ionside network ping will not work.
You need to create an access-list that permits the icmp traffic traveling interfaces. And to ping the same interface that you are connected to, example ping inside IP from an inside host you need to configure the "icmp" command.
examples:
Traceroute
Microsoft:
access-group 101 in interface outside
access-list 101 permit icmp any host YourPublicIP unreachable
access-list 101 permit icmp any host YourPublicIP time-exceeded
access-list 101 permit icmp any host YourPublicIP echo-reply
UNIX:
ICMP command example
icmp deny any outside
icmp permit any echo-reply outside
icmp permit any echo-reply inside
icmp permit host 192.168.1.30 echo inside
icmp permit host 192.168.1.31 echo inside
icmp permit host 192.168.1.20 echo inside
icmp permit host 192.168.1.40 echo inside
icmp permit host 192.168.1.100 echo inside
See: Handling ICMP Pings with the PIX Firewall
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
The PIX and the traceroute Command
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800e9312.shtml
sincerely
Patrick
