IDS 4235 upgrade problem
ahmed_salah
Community Member
hi,
i have IDS 4235 running ver 4.1(1)S47
i want to upgrade it to act as ips i have upgrdae file IPS-K9-maj-5.0-1-S149.rpm.pkg when i start upgrade process i strats copying file from ftp to ids then i got a message
Error: This hardware platform, , is not supported in version 5.x
is there any solution for this problem
5 Replies 5
jamesand
Have you ever replaced any h/w on this sensor? Have you looked for any related errors in the /usr/cids/idsRoot/log/main.log (from service account)?
hi,
IDS still new , please can i know what is the service account which made me see these logs
Logon to your sensor to CLI. Run show users all to see your users. If there is one with a Privilege of Service, logoff and login again with that user account. If a service account does not exist (only one allowed), create one with the following:
configure terminal
username service privilege service
Best of Luck.
You may also want to run "show version" from the cisco account, and verify that it showing the sensor as an IDS-4235 sensor.
There are also older IDS-4230 sensors that are Not supported by version 5.0.
If your sensor is an IDS-4230 and not an IDS-4235 then you will not be able to upgrade to 5.0.
Marco
hi,
thanks for your replay i do what u say and i create
service account please find attached main.log u ask for i found a lot of errors i hope u discover problem source
regards,
ahmed
