IDS 5.1(6)E1 Meta Engine Signatures
hendetl
Is there any documentation that shows ALL signatures associated with a meta signature? Thanks
attmidsteam
The only definitive method is to look at the components of a signature when tuning it (via VMS for example).
attmidsteam
That's what I was trying to avoid but was afraid it was the only way. Oh well, thank you very much for the response. Greatly appreciated.
mhellman
Level 7
Level 7
I'm not sure exactly what your after, but maybe this will help?
Nearly all signatures that are components of a meta signature do not have anything set in the action field. In the IDM, you can sort by the action column and you can copy/paste into Excel and massage as needed.
btw, I'm on V6..but as I recall you can do the same or similar with V5.
