IDSM2 login Problem
blackhat2020
Level 3
Level 3
Hi every one.we have a router 7613 with two configured and running IDSM2's in slot 3 and 4.for some reason i changed one of my idsm2's slot and put it in slot 2.now when i reload my 7613 and when idsm2 comes back online when i try to login to idsm2,non of my usernames and passwords work for login to idsm2 .in this case if i issue command hw-module module 2 reset HDD:1 and reload only my idsm2 ,then when module comes back online every thing is ok and i can login to my module.this strange thing happens with every IDSM2 module that i insert it to slot 2,i dont know what is wrong with my router or i better say my routers slot 2?
This is most probably because you have the bootvar configured for that slot incorrectly (I guess through the 'hw-module boot' command)
Farrukh
Would you be able to provide a "show mod" from the switch while the IDSM2 is failing authentication and a console log of you attempting to authenticate?
You can forward them directly to me or work through a TAC case if you prefer.
Thank you,
Blayne Dreier
[email protected]
Cisco TAC IDS Team
**Please check out our Podcast**
TAC Security Show: http://www.cisco.com/go/tacsecuritypodcast
thanks Blayne,
actually i was checking log files and i saw that when i was loging to idsm2 it was saying that module is in Maintenance mode!! why is this happening to every module that i put in slot 2 i mean if i remove the module and put it in an other slot it will boot normaly not in mantenance mode??? is this slot problem or something else, i dont know why my router puts each IDSM2 module in mantenance mode when they are in slot 2???
Farrukh
thank you guys,I changed Bootvar for slot 2 and it worked.
