IKE Proposals not in LAN-to-LAN
sethan
Hello-
I have a 3000 series Concentrator. I am trying to set up a new Lan-to-Lan. The IKE Proposal I need to use will not show up in the drop down box in Configuration\Tunneling and Security\IPSec\LAN-to-LAN, all the rest of them do. If I go into Configuration\Policy Management\Traffic Management\SAs, it shows up there. Has anyone seen anything like this before? Any insight would be greatly appreciated.
kaachary
Under :
You will find the IPSec Proposals, not IKE. For IKE proposals, you need to go to :
Configuration | Tunneling and Security | IPSec | IKE Proposals
There you need to check if your proposal is in active proposals list or not. If not, you have to add it to Active Proposals.
Hope this helps.
-Kanishka
Hello-
Thank you for your reply. In the path you give I have activated an IKE Proposal that I wish to use. The weird thing is, it does not show up on the drop down list in the LAN-to-LAN settings.
