Inside Interface Addressing problem - PIX 506E
JDShelley
Community Member
I have encountered the following problem, I cannot get the PIX "inside" interface to accept the needed IP address of 10.0.0.250 255.255.255.0 on a network I inherited. I get the following message: "Interface address is not on same subnet as dhcp pool". I get this even when DHCP is disabled in the PIX config. In frustration I have even tried the mask at 255.0.0.0 and configuring DHCP to hand out 10.0.0.x address range IPs. When trying to set DHCP to the 10.x.x.x range I get a similar message: Pool addresses not on same subnet as "inside" interface. I have reset the PIX to default settings several times during theses attempts just to get back to a clean start point. Any help or feedback would be greatly appreciated.
Jack
jmia
Level 11
Level 11
Jack,
You'll need to remove the dhcpd address range in order to change the IP address assigned to the interface serving as the DHCP server interface.
To do this try:
PIX(config)# no dhcpd address 192.168.1.10-192.168.1.50 inside
DHCPD disabled on inside interface because address pool is removed
Now set your inside interface ip address,
> PIX(config)# ip address inside
Save with cmd - write mem.
Hope this helps.
Jay
JDShelley
Community Member
Thanks Jay - That was the resolution. I had evidently only tried that approach with the PDM and not CLI. Thanks Again!
Jack
