Inside interface keeps beeing intermittent
SegBorda
Frequent Visitor
Frequent Visitor
Dears, good morning.
I am passing throw some problems in our border Cisco ASA 5525-X appliance.
Operatinal System Version: 9.12(4)
ASDM: 7.13(1)
The problems are:
1) Our inside interface keeps beeing intermittent. Inside interface keeps going down momentarily in a period of approximately five minutes. It happens several times in a day. The intersting part is is that all new connections and established continue passing throw the firewall. Howerver, I loose connectivity with icmp packets, asdm management access on tcp/443 and SNMP; and
2) The real-time log viewer is not showing all the sources and destinations packets. It keeps showing some source and NAT address.
This problem is impacting our network and I am here to ask for some help, please.
Best regards.
6 Replies 6
Check the switch the inside interface is connected to, run "show logging" and determine whether the interface has any associated error messages.
Dear Rob,
I´m sorry but can you make myself clear?
I did not understand what you wish to tell me with "Check the switch the inside interface is connected to"...
Thanks a lot
The ASA is plugged into a physical switch. I suggested you login to that switch and check the logs to see if there are any errors associated to the interface the ASA is connected to.
Rob,
On my premisses the appliance is connected to a double interface server (netfilter).
That is Netfilter (Oracle Linux) <-> Cisco ASA <-> Internet.
Would you suggest any command?
I got this output:
[root@iptables firewall]# netstat -in
Tabela de Interfaces do Kernel
Iface MTU    RX-OK              RX-ERR    RX-DRP    RX-OVR    TX-OK              TX-ERR     TX-DRP TX-OVR Flg
em1 1500    63108047747  15180      58492      0               75624234823  0               0                 0     BMRU
em2 1500    70552618319  561291    633482    0               34108804279  0               0                 0     BMRU
em3 1500 0 0 0 0 0 0 0 0 BMU
em4 1500 0 0 0 0 0 0 0 0 BMU
lo 65536 1032 0 0 0 1032 0 0 0 LRU
I think I dont have error.
Dears,
I am still having problem.
Can anyone help me, please ?
