Inter VLAN routing using subinterface or VLAN interface
Peyman Sadeghi
Community Member
Hello All,
It seems that there are two methods in Cisco ASA to do the interVLAN routing as below:
1-
Interface Gi 0/0
switport mode truck
switchport allowed vlan 1,2
int vlan 1
ip address 1.1.1.1 255.255.255.0
no shut
Int vlan 2
ip address 2.2.2.2 255.255.255.0
no shut
2-
Interface Gi 0/0
no ip
no shut
int Gi 0/0.1
vlan 1
no shut
int Gi 0/0.2
vlan 2
no shut
Are these methods provide the same functionality/result? Which one is better and why? I want to implement an inter-vlan routing on 9.2.3.
    Jon Marshall
    As far as I am aware the use of vlan interfaces is only for the ASA 5505.
    Any other model of ASA uses subinterfaces and a trunk connection.
    So it depends on your model as to which you use.
    Jon
    Jon Marshall
    Jon
    Peyman Sadeghi
    Community Member
    Thanks Jon yes you are right.
