Intra context communication using a shared interface not working on ASA 8.2.5
hector.ricapa
Frequent Visitor
Frequent Visitor
Hi all,
I was hoping someone could help me with this problem, I have a pair of ASAs in multiple context mode and in a failover configuration, the contexts share a "internet" interface which they use to go outside the world and also in the case one natted server from one context wants to talk to other natted  server in another context. This intra-context traffic has always work.
However we have recently upgraded from version 8.2.2 to version 8.2.5, since then, communication between the contexts using the shared interface is not working.
This is sample of the configuration
CONTEXT-ADMIN
interface GigabitEthernet0/2.1
mac-address 0016.001f.e251 standby 0016.001f.e252
nameif internet
security-level 0
ip address X.Y.Z.2 255.255.255.0 standby X.Y.Z.252
CONTEXT-CTX1
mac-address 0016.001f.e241 standby 0016.001f.e242
nameif internet
security-level 0
ip address X.Y.Z.241 255.255.255.0 standby X.Y.Z.242
as you can see, since this is a shared interface we set the mac-address of the interfaces, however with this version (8.2.5) it seems that one context can't see natted IPs from other contexts. For example I have natted a server on the CTX1 context with the public IP X.Y.Z.43, but from the ADMIN context I just can't see this IP, if I issue the show arp | i X.Y.Z.43 command, it gives me nothing. I also issue a capture command on the ADMIN context and I didnt see any traffic coming from the IP X.Y.Z.43
If I remove the mac-address command from both of the context, I also get no results, now I can see on the ARP tables the natted IPs of the other contexts, but It seem that the traffic gets stuck somewhere in the middle.
I'm pretty sure this could be because of a bug, I have downgrade one of the firewalls and make it the ACTIVE one, this solve the problem. BUT I really would like to know if someone has face this issue and in what version this could be fixed.
praprama
Hi Hector,
This is an interesting situation. You said downgrading to the older version fixes the issue? Can you paste the output of show run all sysopt from both the contexts? I assume that the server has a 1:1 static NAT and not a port redirection correct?
Instead of giving the interface different mac addresses, have you tried using the command mac-address auto in the system mode and see if it affects anything?
Prapanch
