IPS and Switch problem
tareqrebhi
Level 4
Level 4
Dears,
i need to use commands:
monitor session 1 source interface Fa0/1 - 23
and
monitor session 1 destination interface Fa0/24
but when i put the second command i lost the connection with IPS sensor......what is the problem?
thank you.
pciaccio
Level 9
Level 9
By making your port a SPAN port to in essence mirror all traffic to the destination port from your source port(s). You cannot interact on the destination port. I mean that the destination port does not function as an access port anymore until you remove the SPAN from it. You need to find an alternate path to your IPS. Either from the outside or console....
