Is nat-control required for static nat
Mike Schooley
is nat control required for static nat
Static NAt is typically from high security level to low security level.
So can you please advise what you are trying to NAT from and to? Please advise the real ip address on the server, and the ip address that you would like the server to NAT to.
5 Replies 5
Jennifer Halim
No, nat-control only controls "nat" statement, not static nat statement.
I was afraid you would say that, then why isn't my nat working posted below pertinent config  odd thing is i dont see anything in fw logs
interface Ethernet0/0.299
description ### APP ZONE 2 TEMPLATE ###
vlan 299
nameif DMZ-299
security-level 0
ip address 10.2.99.250 255.255.255.0 standby 10.2.99.253
interface Ethernet0/2.399
description ### APP ZONE 3 TEMPLATE ###
vlan 399
nameif DMZ-399
security-level 100
ip address 10.3.99.254 255.255.255.0 standby 10.3.99.253
static (DMZ-299,DMZ-399) 10.3.99.10 10.2.99.60 netmask 255.255.255.255
access-group DMZ-299_access_in in interface DMZ-299
access-list DMZ-299_access_in extended permit ip any any
sho xlate
1 in use, 2 most used
Global 10.3.99.10 Local 10.2.99.60
you already have a NAT  translation for the addresses you are trying to do static NAT.
Can you do a sh run nat and sh run global.
DMZ-299 has security level lower than DMZ-399 and usually static NAT is for natting high to low which is reverse of what you are doing  here.
Regards.
Alain.
your right, I don't usually use the gui, and my nat statement was backwards.
changed it to
static(dmz-399,dmz-299) 10.2.99.60 10.3.99.10 ...
worked fine.
