Lab-to-Lan EasyVPN between PIX and Concentrator 3000
colomacrespi
Hi to all,
I?m trying to set an EasyVPN connection between a PIX Firewall and a Concentrator 3000.
Some details about the configuration:
-I?m using client extension mode for the EasyVPN connection.
-PIX private interface network is: 10.0.10.0/24
-PIX public interface uses DHCP.
-The user created on the Concentrator to get the connection from the EasyVPN Client is PIXPlug&Play.
I manage to establish the tunnel. I also manage to trasmit traffic from the PIX to the concentrator. But I never get a response.
I have check routes after the concentrator in our LAN for the network 10.0.10.0, and they are ok (10.0.10.0 255.255.255.0 172.19.128.206(concentrator private IP)).
I attach the PIX and Concentrator?s configurations and logs.
I'm hopeless about this problem... Any idea will be wellcome...
Thanks in advance,
Coloma Crespi
Thanks for the information mate!
But I?d already checked this before posting this message...
Any ideas about why the tunnel establishes but does not pass traffic accross it?????
