LMS 2.5.1 homepage problem!
gagatiello
Hello. I have updated LMS from 2.2 to 2.5.1. All the migration has been satisfactory, but now I´ve a problem with the visualization of the homepage.
If all the applications are registered, the RME and the IPM do not visualize in the homepage (image attached cw1).
But if for example unregister the CiscoView, the RME and the IPM appear (image cw2). Testing different combinations, the homepage changing, but never I can see everything simultaneously.
Ideas?
mchin345
Level 6
Level 6
From the Common Services tab in the CiscoWorks homepage, select Server > Security. The Security Settings page appears.
From the TOC pane, select Cisco.com User Account Setup. The Cisco.com User Account Setup page appears.
Enter the desired username in the Username field.
Enter the desired password in the Password and Verify Password fields.
Click Apply
Hello! That answer is for my question?
I have already configured the Cisco User Account and that works correctly. but it does not solve the visualization problems.
Thanks anyway
