Manage ASA with ip inside interface from outside network
Kool1sttt
Assume i use two interface of ASA(inside & outside). How can manage ASA form outside network with ip on insde interface of ASA.
Ganesh Hariharan
Normal recommendation is to make access availble via same interface by allowing few public ip on outside interface under asa interface stating range or static ips.
But do you know why you want to allow this type of scenario ?
Hope it Helps..
-GI
