Maximum Limits and Questions
emusican
Level 3
Level 3
Im about to start a project which could take my total sensor count well over 100, over time, using CiscoWorks VMS 2.2 UNIX Unrestricted. I am guessing that a vast increase of sensors brings along with it some unique problems. I would like to ask those of you out there that manage 100 + IDS deployments for some useful advice in overall functioning and use of the IDSMC & SecMon in such an environment.
I just cant see security monitor handling 100 + sensors, with someone looking for a needle in a haystack. Granted it is better to spot things in 4.x then 3.x icons, but there is still a lot of info to go through. The only thing I could think of is to baseline the sensor to the point where barely anything minor-moderately serious shows up. Its going to be a monumental undertaking.
By the way, I know Cisco says that there is no limit of sensors you can add to the IDSMC & MC, but what is the practical limit? Has anyone reached it?
Any suggestions would be appreciated.
mchin345
Level 11
Level 11
This is really a number of alerts per second question rather than number of sensors. A well tuned sensor should send only an alarm or two per second. So you are already on the right track.
