multi context / multi sub-ints -- route to single interface
tsrader
Level 3
Level 3
config is similar to multiple context using "shared interface".
Can multiple inside sub-interfaces (VLANS) route to a single interface on L3 switch? or does each sub-int need to route to a physical interface?
L3 vlans not config'd on core switch to keep lab pc's isolated from rest of network
Config attached for clarification
Jon Marshall
Terry
No you can't do this. Multiple vlans means multiple vlan interfaces on your L3 switch or you make the connection between your L3 switch and the inside interface of your ASA a L2 trunk link.
Jon
