Multiple Port Channels using same VLANS? FP1010
nickh1234
Community Member
Currently I have a Firepower 1010 managed by FMC.
I want to have 2 x VLANS, a management VLAN (100) and then a LAN VLAN (with DHCP) (200).
From then I want to have 2 port channels (EtherChannels) with 2 Ethernet Ports each which will then go to 2 x switches configured with a Port Channel.
I can't seem to figure out how I can create 2 x Port Channels with both VLAN 100 and 200 trunked through them via FMC.  I have tried with subinterfaces but it will only let me use a VLAN once and only if it doesn't exist.
On an ASA switch I would just create the port channel using the basic commands then add the interfaces to the port channels but I can't seem to figure this out in FMC.
0 Replies 0
