Naming Conversion is not happening in cisco ASA 5520
Madhan Kumar
We have three Cisco ASA 5520 with 8.2 code in each tower. There are many configuration on the device hence we are using ip to Name to identify the naming conversion. Out of three one firewall naming conversion is not working, I mean after adding name for a IP it is not reflecting vpn tunnels or access lists or Nat config. Can anyone can help to fix this issue.
Thanks & Regrads
R.MADHANKUMAR
Jouni Forss
Do you mean the IP to Name that is at the very start of the ASA configuration when checking it from CLI?
Are you sure that someone hasnt configured "no names" instead of the "names" which is to my understanding required for the name to replace the IP address in the configurations.
Personally I don't use the configurations mentioned. Maybe do some IP to Name mappings but dont have them used in the actual configured by issuing "no names"
- Jouni
