NAT Problem - FWSM
Hi guys,
I have a problem in FWSM where the following happens:
- I have 2 instances called fW01 and fw02.
- When I create an interface in the same VLAN in the 2 instances, the NAT does not work.
Upgraded the FWSM version 2.3 to 4.1 to try to fix this problem, but still does not work.
They would know tell me if it is some configuration problem or is it a bug?
Thank you.
Jouni Forss
Can you share some configurations for us to go through?
Sadly I've gotten a bit rusty on the FWSM side and mostly used new ASAs
Can you share the version of the configuration before and after the change you are trying to do?
Is the situation the following
  • You have a single FWSM running in multiple context mode
  • You have 2 Security Contexts on that FWSM
  • You are trying to add a single created Vlan interface to both Security Contexts?
- Jouni
Jouni,
Correct
  • You have a single FWSM running in multiple context mode - YES
  • You have 2 Security Contexts on that FWSM - YES
  • You are trying to add a single created Vlan interface to both Security Contexts? - YES
Follow below the configuration:
FW01
interface Vlan12
nameif NET-LAN
security-level 100
ip address 10.10.10.1 255.255.255.0
access-list NET-LAN extended permit ip 10.10.10.0 255.255.255.0 10.30.0.0 255.255.255.0
access-list NET-LAN-INTERNET extended permit ip 10.10.10.0 255.255.255.0 10.30.0.0 255.255.255.0
nat (NET-LAN) 10 access-list NET-LAN-INTERNET
global (DMZ-PUBLIC-ROB) 10 10.30.0.10
____________________________________________________________________________________________
FW02
interface Vlan12
nameif NET-LAN
security-level 100
ip address 10.10.10.2 255.255.255.0
access-list NET-LAN extended permit ip 10.10.10.0 255.255.255.0 10.31.0.0 255.255.255.0
access-list NET-LAN-INTERNET extended permit ip 10.10.10.0 255.255.255.0 10.31.0.0 255.255.255.0
global (DMZ-PUBLIC-CAR) 10 10.31.0.10
_____________________________________________________________________________________________
In this case the NAT doesn't work.
Thanks!!
I'm not quite sure if I'm getting the whole picture of the network but the Policy NAT configuration doesnt seem that complex.
Seems you have the following setup
  • The mentioned 2 Security Context are connected by Vlan12 to the same NET-LAN
  • The mentioned 2 Secuirty Context have different DMZ networks behind them
  • In both cases you want to Policy NAT the traffic coming from the NET-LAN to the DMZ in question so that the given NAT address belongs to the same network as the actual destination host?
  • On the NET-LAN side you probably have static routes pointing towards each context for the DMZ networks.
If this is the case can you specify how you confirm that the NAT is not working?
Are you taking the "show xlate" output for the connections? Can you get some log messages of the connection attempts?
Only NAT rule that should override the Policy NAT (to my understanding) is either a more specific Policy NAT rule or NAT0/NAT Exempt rule. Going between the old NAT and new NAT does get me confused sometimes so I'm not 100% sure.
- Jouni
