Need Firepower replacement for ASA 5510
baskervi
I'm a bit frustrated. I spent probably 30 minutes looking for a replacement on Google, and I saw lots of references to the ASA-5512-X and 5515-X, but end of life isn't too far out. I then chatted with Cisco for nearly 25 minutes and was getting transferred to the 4th person last Friday but was heading out of town and dropped the call. It's not rocket science.
We need full 1Gbps NICs and the NGFW features. We will be terminating 16 site-to-site VPN tunnels. Does the 2110 somewhat map over to the 5510? Does another firewall fit the bill better? Thanks
If you are looking for a 1 to 1 match then I think the closest is FTD 1140 (based on throughput and VPN peers, etc.).  But if you have the budget then the 2110 is a good firewall to grow into.
Datasheets
FTD1000
https://www.cisco.com/c/en/us/products/collateral/security/firepower-1000-series/datasheet-c78-742469.html
FTD2100
https://www.cisco.com/c/en/us/products/collateral/security/firepower-2100-series/datasheet-c78-742473.html
Please remember to select a correct answer and rate helpful posts
Marvin Rhoads
For a single appliance setup I'd recommend the Firepower 1120 running FTD with the basic Threat license.
If you're doing more than 1 or 2 of them (or would just like centralized cloud-based management) the I would also go with the Cisco Defense Orchestrator (CDO) management option.
