Need help: ASA 5505 i2c_read_word_w_wait() error
yuminyang
Anyone know a simple fix for this? or or any one can fix this for me, and how much the cost is? Or I should discard it?
Below is the console output when power is connected.
more info: It stuck at line:    Cisco Systems ROMMON Version (1.0(12)13) #0: Thu Aug 28 15:55:27 PDT 2008   for long time.
Thanks.
-yumin
buscontact@gmail.com
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)13 08/28/08 15:50:37.45
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  01  00   1022   2080  Host Bridge
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0C  00   1148   4320  Ethernet           11
00  0D  00   177D   0003  Network En/Decrypt 10
00  0F  00   1022   2090  ISA Bridge
00  0F  02   1022   2092  IDE Controller
00  0F  03   1022   2093  Audio              10
00  0F  04   1022   2094  Serial Bus         9
00  0F  05   1022   2095  Serial Bus         9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
i2c_read_word_w_wait() error, slot = 0x0, device = 0x64, address = 134 byte count = 2. Reason: I2C_UNPOPULATED_ERROR
Platform ASA5505
Ethernet0/0
i2c_write_byte_w_wait() error, slot = 0x0, device = 0x64, address = 128 byte count = 1. Reason: I2C_UNPOPULATED_ERROR
esw_reg_read: i2c_write_byte_w_wait(0) returned 0x6
Ethernet port 0 could not be initialized.
Default Interface number-0 Not Up
Use ? for help.
rommon #0>
julomban
Level 3
Level 3
Yumin,
Please try to set the config register value to 0x1:
rommon #0> confreg 0x41
And reload the ASA by entering the following command:
rommon #0> boot
If that doesn’t work I am afraid that is more a hardware failure.
Juan Lombana
Thanks, Juan.
I believe it is a hardware problem too.
It looks like that it has some problem to communicate with 'device = 0x64, address = 134' which is faulty. It may be related to port 0.
Anyone experts know what this device is? It it replaceable?
Yumin,
If this is a new unit you should get back to your reseller or vendor otherwise you need to open a case with us so we can replace the unit (Cisco TAC).
Juan Lombana
Please rate helpful posts.
