Need help interpreting static command
stindall
Community Member
I have one device on a subnet that cannot reach some wireless anchor controllers in our DMZ.  I've noticed some static statements that appear to me to dead end the address.  I would appreciate some help figuring out why these commands are in our ASA as I have little experience.
static (inside,dmz_wifi) A.A.A.A A.A.A.A netmask 255.255.255.255
static (inside,icon)  A.A.A.A A.A.A.A netmask 255.255.255.255
where A.A.A.A represents the same IP address in each case.
For example: static (inside,dmz_wifi) 192.168.7.7 192.168.7.7 netmask 255.255.255.255
I would appreciate any help you can provide.
Steve
Jon Marshall
Steve
By default traffic is not allowed from a lower security interface to a higher security interface without -
1) an acl allowing the traffic
and
2) if you have nat control enabled a static NAT statement for the inside IPs
what that statement is doing is presenting the internal IP of 192.168.7.7 to the dmz_wifi so that connections can be initiated from machines in the dmz_wifi to that IP address on the inside.
The reason it is the same IP is simply because you don't actually want to present it as a different IP but you still need a NAT statement for it.
It's called identity NAT.
So from your statements I assume that both the icon and dmz_wifi interfaces have a lower security level than the inside interface ?
Jon
Yes.  Inside is 100, the other two are 20.  If I understand this properly this rule will allow 192.168.7.7 to establish a connection to icon or dmz_wifi but not to any other interfaces nor will it allow something on those interfaces to establish a connection TO the address.
Interesting.  Still seems like an unnecessary command for our purposes but I don't expect you to understand our environment without a lot more discussion.  I'll take it up with some local talent tomorrow.
I appreciate your quick and thorough answer and your willingness to share your experience.
Steve
Steve
Just to clarify the second part.
If you mean it won't allow connections from devices on other interfaces ie. not icon or wifi_dmz then yes correct.
But it will allow connections to be initiated from devices on the icon or wifi_dmz interfaces.
I think that is what you were saying, just wanted to be sure 🙂
Jon
I didn't expect it to work both ways.  I guess I'm as good as a weather forecaster - 50% right.
Thanks again.
