need help with ASA 5512 configuration
tranatisoc
Hi - i'm novice to asa configuration.  please could someone help me with performing the following:
https://support.zoom.us/hc/en-us/articles/201362683-Network-Firewall-or-Proxy-Server-Settings-for-Zoom
thanks in advance
5 Replies 5
jumora1
please attach the configuration and detail on your issue
Security Engineer
juanmh8419@gmail.com
Skype: juanmh8419@hotmail.com
I need to add this to my config:
TCP80,443All Zoom Clients
*.zoom.us
TCP443, 8801, 8802All Zoom Clients8.5.128.0/23
52.202.62.192/26
64.211.144.0/24
69.174.57.0/24
115.114.131.0/26
162.12.232.0/22
162.255.36.0/22
192.204.12.0/22
202.177.207.128/27
202.177.213.96/27
204.141.28.0/22
209.9.211.0/24
213.19.144.0/24
213.19.153.0/24
221.122.88.128/25
221.122.89.128/25
and so on.
By default the ASA does not block traffic from the inside interface out.
Can you get a copy of the configuration of the ASA so I can check from which interface behind the ASA you are coming from and if you have any filtering rules that could be blocking you.
Security Engineer
I'm trying to figure out how to copy my config.  two questions:
1) is it safe to post config on public forum such as this?
2) does my config contain any sensitive data such as passwords?
passwords are encrypted you can XXX out anything related to IP addresses and routes but if you feel this is sensitive information please open a TAC case.
Security Engineer
