Need help with configuration
jason0923
I'm new to Cisco and we just took over a client with an ASA 5505 I need to do 2 things first
I  need to know how to open or forward ports to an internal IP address   they want me to open ports 3389 and 1433 to an internal address   192.168.192.52
but only from       207.235.73.64 and 255.255.255.192
                              40.143.46.64 and 255.255.255.192
o      and
      66.192.91.128 and 255.255.255.192
      40.143.28.64 and 255.255.255.192
And  second Id link to getb the ASDM downlaoded and working as I;ve used  that before in other offices and it helps me out as a non cisco expert. I  try going to the device IP in a browser 192.168.192.1/admin and just  get a prompt for username and password but it doesn;t take the one I  have. Here is the config on the device right now. Any help you guys can  point me to Id appreciate. 4 hours of Google research has gotten me no  where
sho run
: Saved
ASA Version 7.2(3)
hostname vmine
domain-name mine
enable password CyQcVKTj6CW8.Vsj encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.192.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.248
interface Vlan3
mac-address 001f.6ce3.bd99
no forward interface Vlan1
nameif guest
security-level 10
ip address 205.10.2.1 255.255.255.0
interface Ethernet0/0
description Internet-Connection
switchport access vlan 2
interface Ethernet0/1
description Connection to Inside Network
speed 100
duplex full
interface Ethernet0/2
shutdown
interface Ethernet0/3
interface Ethernet0/4
switchport access vlan 3
interface Ethernet0/5
description Connection to Public Network
speed 100
duplex full
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
passwd CyQcVKTj6CW8.Vsj encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name domain
access-list guest extended permit icmp any any
access-list guest extended permit ip any any
access-list inside extended permit icmp any any
access-list inside extended permit ip any any
access-list outside extended permit icmp any any echo-reply
access-list outside extended permit tcp any any eq 8440
access-list nonat extended permit ip 192.168.192.0 255.255.255.0 192.168.252.0 255.255.255.0
access-list outside-in extended permit tcp any any eq https
access-list outside-in extended permit tcp host x.x.x.x any eq 1433
pager lines 24
logging enable
logging buffer-size 16384
logging buffered informational
mtu inside 1500
mtu outside 1500
mtu guest 1500
ip local pool vpn-ip 192.168.252.1-192.168.252.
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm.bin
no asdm history enable
arp timeout 14400
global (outside) 1 x.x.x.x
global (outside) 2 x.x.x.x
nat (inside) 0 access-list nonat
nat (inside) 1 192.168.192.0 255.255.255.0
nat (guest) 2 205.10.2.0 255.255.255.0
static (inside,outside) tcp interface www 192.168.192.170 www netmask 255.255.255.255
static (inside,outside) tcp interface https 192.168.192.170 https netmask 255.255.255.255
static (inside,outside) x.x.x.x 192.168.192.52 netmask 255.255.255.255
access-group inside in interface inside
access-group outside-in in interface outside
access-group guest in interface guest
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 0.0.0.0 0.0.0.0 inside
http 192.168.192.0 255.255.255.0 inside
snmp-server host inside 192.168.192.10 poll community ciscosnmp
snmp-server location PIX
no snmp-server contact
snmp-server community ciscosnmp
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
crypto ipsec transform-set DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map dynvpn 10 set transform-set DES-MD5
crypto map vpn 65535 ipsec-isakmp dynamic dynvpn
crypto map vpn interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5
group 2
lifetime 28800
crypto isakmp nat-traversal  20
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 30
console timeout 0
dhcpd dns 209.253.113.10 209.253.113.18
dhcpd address 205.10.2.10-205.10.2.99 guest
dhcpd dns 209.253.113.10 209.253.113.18 interface guest
dhcpd enable guest
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ipsec-pass-thru
service-policy global_policy global
group-policy RA-VPN internal
group-policy RA-VPN attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value nonat
username VMRemote password .RSNgq92vZTSELWV encrypted
username VMRemote attributes
vpn-group-policy RA-VPN
username VMVPN password jSqp8CjjxHhRa6jk encrypted
username kernels password jDS98nJtthzlEvw5 encrypted
tunnel-group VMVPN type ipsec-ra
tunnel-group VMVPN general-attributes
address-pool vpn-ip
tunnel-group VMVPN ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:52c3d65fc1111c561b1598cc341dc6d5
: end
8 Replies 8
Vibhor Amrodia
As per your 1st query , I think he Static NAT should work fine.
To restrict the access from the outside only for certain IP , you can use Source Based ACL:-
access-list outside-in extended permit tcp 207.235.73.64 255.255.255.192 host x.x.x.x eq 3389
access-list outside-in extended permit tcp 40.143.46.64 255.255.255.192 host x.x.x.x eq 3389
access-list outside-in extended permit tcp 66.192.91.128 255.255.255.192 host x.x.x.x eq 3389
access-list outside-in extended permit tcp 40.143.28.64 255.255.255.192 host x.x.x.x eq 3389
access-list outside-in extended permit tcp 207.235.73.64 255.255.255.192 host x.x.x.x eq 1433
access-list outside-in extended permit tcp 40.143.46.64 255.255.255.192 host x.x.x.x eq 1433
access-list outside-in extended permit tcp 66.192.91.128 255.255.255.192 host x.x.x.x eq 1433
access-list outside-in extended permit tcp 40.143.28.64 255.255.255.192 host x.x.x.x eq 1433
If you would like to use the LOCAL username and Passowrd on the ASA:-
aaa authentication http console LOCAL
Thanks and Regards,
Vibhor
So are those commands with 192.168.192.52 in place of x.x.x.x all I need or is that just to restrict access.
For the ASDM I don't know what you mean by would I like to. I have a password I am using to login via ssh. IS that not the same login to get to this asdm page in the browser?
Hi Jason,
This is the Static NAT as per your requirement already configured on the ASA device.:-
If you would like to restrict access from the Outside , you have to use the ACL as mentioned above.
I would request you to add this command to LOGIN to the ASDM using the username and Password:-
Thanks and Regards,
Vibhor
I'll try that for the NAT, for the ASDM I don't have the ASDM S/W installed in other places I could download it from the device which is what I'm trying to do here. So will this command allow me to get to the device from the browser to downlaod the ASDM client? Also will the command aaa authentication http console LOCAL disable anything else like  my current ssh login?
I added the
aaa authentication http console LOCAL command and still cannot access the device via the browser.
Is the asdm image in the ASA flash memory and specified as the image?
# sh disk0:/       <-- To look into the flash
# sh asdm image    <-- To show the current asdm image being served up
ASDM 5.2(4) is the recomended software for the ASA sofware version 7.2
Above, it says "asdm.bin" but usually the filename is more descriptive, for example:
ASA-FW# sh asdm image
Device Manager image file, disk0:/asdm-713.bin
In addition to the above recommendations , I would request you to get these output:-
show asp table socket
show run http
Java Version on your PC
Thanks and Regards,
Vibhor
To answer your questions it says asdm-523.bin
show asp table socket gives me a syntax error
sho run http gives me
I'll check the java version on the server I'm using when I can but the broiwser is asking me for a login and pwd when i try and access the asa so i don't know if Java is even being used at that point
