Need to allow ping to switch connected to DMZ from outside
mahesh18
Level 6
Level 6
Hi everyone,
Current config from ASA  allows telnet to switch which is connected to DMZ of ASA  from outside connection of ASA.
IS there any way that i can also allow ping to this switch from outside at the same time.
Can ping and telnet work at same time from outside switch which is connected to  outside interface of ASA  to DMZ  switch.
DMZ  switch IP is 192.168.69.1
Outside interface of ASA  IP  192.168.11.2
Switch connected to outside interface of ASA IP 192.168.11.1
current config
ciscoasa#                                  sh running-config
: Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 11
interface Ethernet0/1
switchport access vlan 12
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 100
ip address 192.168.52.1 255.255.255.0
interface Vlan11
nameif outside
security-level 0
ip address 192.168.11.2 255.255.255.0
interface Vlan12
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 192.168.69.2 255.255.255.0
regex facebook "\.facebook\.com"
boot system disk0:/asa825-k8.bin
ftp mode passive
clock timezone MST -7
clock summer-time MST recurring
access-list facebook extended deny tcp host 192.168.69.4 any eq www log
access-list facebook extended permit tcp any any eq www log
access-list ACL extended permit icmp any host 192.168.69.4 echo
access-list DMZ-NAT0 extended permit ip 192.168.69.0 255.255.255.0 192.168.11.0 255.255.255.0 log
access-list outside_in extended permit tcp host 192.168.11.1 host 192.168.69.1 eq telnet log
pager lines 24
logging enable
logging timestamp
logging buffer-size 12288
logging buffered debugging
logging asdm debugging
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (DMZ) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (DMZ) 0 access-list DMZ-NAT0
nat (DMZ) 1 192.168.69.0 255.255.255.0
access-group outside_in in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.11.1 1
route DMZ 192.168.77.0 255.255.255.0 192.168.69.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
http server enable
http 192.168.0.0 255.255.0.0 inside
http 192.168.0.0 255.255.0.0 DMZ
http 192.168.0.0 255.255.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=ciscoasa
crl configure
crypto ca certificate chain ASDM_TrustPoint0
certificate cda15b51
    308201cf 30820138 a0030201 020204cd a15b5130 0d06092a 864886f7 0d010105
    0500302c 3111300f 06035504 03130863 6973636f 61736131 17301506 092a8648
    86f70d01 09021608 63697363 6f617361 301e170d 31333034 30333033 33313134
    5a170d32 33303430 31303333 3131345a 302c3111 300f0603 55040313 08636973
    636f6173 61311730 1506092a 864886f7 0d010902 16086369 73636f61 73613081
    9f300d06 092a8648 86f70d01 01010500 03818d00 30818902 818100c5 04be4392
    051ff956 1786981c 6acbe7ed 880bc95a 1c846bf4 19e381f7 f1e8d0d0 e340f86f
    e94ec55b a1714de8 19976ae4 e9196c52 7791873c 794d2eec 4ae90aa5 5b40282c
    3aac7fbb 2a2a2e36 77906a25 a3874d98 7f51e370 266068d8 f5adbd97 bd204ce0
    61943442 ae73ce78 4f2b0daa 53374044 07f4df39 eed0e80c 2b92af02 03010001
    300d0609 2a864886 f70d0101 05050003 8181001e 41c1636b c86357f6 94585bc0
    2fe4bf2f b9f0cc4a 108f3cbf 830ebe54 fb6c87e6 04ad11a4 3fec5ced 5f6f9784
    9f423788 c7de4b5b b7226d81 262ee3b6 ff0adffe 4e49ed7a 42c74d4b f52f0456
    1b8feb3f f19efdc5 adaced62 c4bd7180 107feb06 8658937e 8cb2a154 7486de37
    9b00c44c d17f967e 5fbe4584 c71fd389 55d670
  quit
telnet timeout 5
ssh 192.168.0.0 255.255.0.0 inside
ssh 192.168.0.0 255.255.0.0 outside
ssh 192.168.0.0 255.255.0.0 DMZ
ssh timeout 60
ssh version 2
console timeout 0
dhcpd dns 64.59.144.19
dhcpd address 192.168.52.5-192.168.52.15 inside
dhcpd enable inside
dhcpd address 192.168.69.3-192.168.69.20 DMZ
dhcpd enable DMZ
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 192.168.11.1
webvpn
username mintoo password AILiHuRWFGgkbsI5 encrypted privilege 15
class-map facebook
match access-list facebook
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map type inspect http test
parameters
match request header host regex facebook
  reset log
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
  inspect icmp error
class facebook
  inspect http test
class class-default
  set connection decrement-ttl
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:70b9f5bac4c6b6146672a8ca214639cc
: end
Mahesh
3 Accepted Solutions
Jouni Forss
Hi Mahesh,
Are we talking about purely L2 Switchs or L3 Switches doing routing?
Does the Telnet work already?
You naturally need to open ICMP from the "outside" to allow the traffic since at the moment only Telnet is allowed.
access-list outside_in extended permit icmp host 192.168.11.1 host 192.168.69.1 echo
If the Telnet isnt even working between the switches then you might be lacking the "ip default-gateway" configuration from both of the switches.
- Jouni
It should work if the source was "any" also.
Can you tell me what ACL/configuration you were using that didnt work?
In the above configuration I can only see Telnet opened from OUTSIDE to DMZ. So in the above configuration ICMP was not possible.
If you added some configuration before I am not sure why it didnt work.
- Jouni
I dont think you can do that. You can only ping an interface from a host behind that interface. Not from behind another interface.
- Jouni
6 Replies 6
Jouni Forss
Hi Mahesh,
- Jouni
Hi Jouni,
Telnet is working fine from outside to DMZ  switch.
Switch connected to outside is Layer 3 and switch connected to DMZ is layer 2 only.
DMZ switch has default route of 192.168.69.2.
Seems i tried few times icmp command but seems i was trying any instead of host 192.168.11.1 command in the above config
thats the reason it was not working.
now i config the above ACL and it worked like charm..
Can you please explain me why using any as source did not work?
Also while using source as any icmp request was coming from 192.168.11.1 to 192.168.69.1 but reply was not coming back?
3550SMIB#ping 192.168.69.1
Sending 5, 100-byte ICMP Echos to 192.168.69.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Mahesh
- Jouni
Hi Jouni,
Now it worked using source as any also.
May be i was doing something wrong.
Is pinging to DMZ  interface IP  from outside switch possible?
MAhesh
- Jouni
Thanks Jouni again.
Mahesh
