Need to block HTTPS traffic in CSC module
alexageorge
Level 2
Level 2
I am having an ASA5510 with a CSC-SSM-10 module. I am able to block http traffic through the ASA but cannot block https traffic through it. Can anyone please help me in blocking https traffic using the CSC module.
Alex George
19 Replies 19
Hi Stephan,
Please find the attachement (page 10 under important notes).
http://www.cisco.com/en/US/docs/security/csc/csc66/administration/guide/csc4.html#wp1098890
Alex George
Hi Varun,
I was able to block the https traffic by giving *.xxxx.com (eg, *.facebook.com) in the https block option. But I am facing another problem. I am able block the https traffic in firefox and chrome but is able to access the site in IE. I checked in IE6 and IE8 where the sites were able to be opened.
Alex George
alexageorge
Level 2
Level 2
Hi All,
As mentioned in the post I am still facing the problem with filtering https traffice with SSM-CSC-10 module. And I find the this is a drawback of the the same.
Now, I am facing a different kind of issue. When I am trying to access sites that has not been blocked in https filter, I am getting an SSl error mostly.
Attaching the screen shot along. Can anyone help me with this.
Alex George
alexageorge
Level 2
Level 2
Hi All,
Alex George
HI Alex George,
In the URL filtering, uncheck the unrated sites in the Generel tab.
And also check the configuration in the webreputation.
Janardhan
