Need to know how to block using SVIs with IDSM-2
dmarsh
I have been unable to get the SVIs on a Catalyst 6506 Sup720 to block using an IDSM-2 (v5.1.1g).
Relevant configuration Info:
Server ---(VL60)---SVI60[10.1.60.1/24]----SVI80[10.1.80.1/24]---IDSM2[Promiscuous, not inline]--(VL80)---PC[10.1.80.25/24]
interface Vlan80
ip address 10.1.80.1 255.255.255.0
access-list 2000 permit ip any any
vlan access-map PREBLOCK 10
match ip address 2000
action forward capture
vlan filter PREBLOCK vlan-list 80
intrusion-detection module 6 management-port access-vlan 99
intrusion-detection module 6 data-port 1 capture
intrusion-detection module 6 data-port 1 capture allowed-vlan 80
cat6k-devices 10.1.80.1
communication ssh-des
profile-name Outside_Router
block-vlans 80
pre-vacl-name 2000
signatures 60001 0
alert-severity high
sig-fidelity-rating 75
sig-description
sig-name Block BadICMP
sig-string-info Block BadICMP
sig-comment Block BadICMP
exit
engine atomic-ip
event-action produce-alert|request-block-host
specify-l4-protocol yes
l4-protocol icmp
specify-icmp-seq no
specify-icmp-type no
specify-icmp-code yes
icmp-code 8
exit
specify-icmp-id no
specify-icmp-total-length no
exit
specify-payload-inspection no
exit
specify-ip-payload-length no
specify-ip-header-length no
specify-ip-tos no
specify-ip-ttl no
specify-ip-version no
specify-ip-id no
specify-ip-total-length no
specify-ip-option-inspection no
specify-ip-addr-options yes
ip-addr-options ip-addr
specify-src-ip-addr yes
src-ip-addr 10.1.80.25
exit
specify-dst-ip-addr no
exit
exit
exit
event-counter
specify-alert-interval no
exit
alert-frequency
summary-mode summarize
specify-global-summary-threshold no
exit
IDSM2-PODX# packet display gigabitEthernet0/7
Warning: This command will cause significant performance degradation
tcpdump: WARNING: ge0_7: no IPv4 address assigned
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on ge0_7, link-type EN10MB (Ethernet), capture size 65535 bytes
14:42:23.334127 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 3066
14:42:24.335289 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 3322
14:42:25.336257 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 3578
14:42:26.338406 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 3834
14:42:27.339528 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 4090
14:42:28.341637 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 4346
14:42:29.343774 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 4602
14:42:30.344715 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 4858
14:42:31.346860 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 5114
14:42:32.348013 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 5370
14:42:33.350168 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 5626
14:42:34.352024 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 5882
14:42:35.353130 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 6138
14:42:36.355325 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 6394
14:42:37.356463 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 6650
14:42:38.358607 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 6906
14:42:39.360561 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 7162
14:42:40.361706 IP 10.1.60.10 > 10.1.80.25: icmp 40: echo reply seq 7418
18 packets captured
18 packets received by filter
0 packets dropped by kernel
IDSM2-PODX#
dmarsh
Part 2 of Info:
CAT65K-PODX# sh ver
IOS (tm) s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)S
XF4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Mar-06 19:38 by tinhuang
Image text-base: 0x40101040, data-base: 0x42DA8000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)S
CAT65K-PODX uptime is 7 weeks, 7 hours, 55 minutes
Time since CAT65K-PODX switched to active is 7 weeks, 7 hours, 54 minutes
System returned to ROM by power cycle (SP by power on)
System image file is "disk0:s72033-adventerprisek9_wan-mz.122-18.SXF4.bin"
CAT65K-PODX#
CAT65K-PODX# sh mod
Mod Ports Card Type Model Serial No.
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL084359BZ
4 8 Network Analysis Module WS-SVC-NAM-2 SAD095005X4
5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAL09412WB4
6 8 Intrusion Detection System WS-SVC-IDSM-2 SAD101601NR
Mod MAC addresses Hw Fw Sw Status
3 0012.435d.8b68 to 0012.435d.8b97 2.1 12.2(14r)S5 12.2(18)SXF4 Ok
4 0012.80f1.d8c0 to 0012.80f1.d8c7 4.0 7.2(1) 3.4(1a) Ok
5 0013.7f0a.ff48 to 0013.7f0a.ff4b 4.3 8.1(3) 12.2(18)SXF4 Ok
6 0016.9dab.3340 to 0016.9dab.3347 6.1 7.2(1) 5.1(1) Ok
Mod Sub-Module Model Serial Hw Status
3 Centralized Forwarding Card WS-F6700-CFC SAD084205DY 2.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3BXL SAL09412SXU 1.6 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL09412HDB 2.3 Ok
6 IDS 2 accelerator board WS-SVC-IDSUPG ADEI6120088 2.4 Ok
Mod Online Diag Status
3 Pass
4 Pass
5 Pass
6 Pass
CAT65K-PODX#
I have attached the current Cat6K/Sup720 full configuration and the IDSM-2 configuration.
The million dollar question:
Why can?t I enforce blocking on SVI80? I have defined everything according to the docs and both options [blocking and rate limiting] are grayed out in my blocking device definition. I understand from the docs that rate limiting is not supported on VACLS, but if I am reading it correctly, ACLs should be.
So I have determined that I needed an ACL applied to the SVI as opposed to the VACL used for capture. I added:
ip access-list 2020
permit ip any any
Interface Vlan 80
ip access-group 2020 in
I still do not get the option to block in IDM. Does this need to be added as a Cisco router (doesnt seem to want to take Vlan80 as an interface) or a Cat6k blocking device?
All help appreciated. Thanks in advance.
