Needs help to ping out of ASA 8.0.2
engineer_msu
Hi All,
I need help to ping through firewall. Please help me. I am getting this error while trying to ping outside:
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (inspect-icmp-seq-num-not-matched) ICMP Inspect seq num not matched
4 Accepted Solutions
You simutale an ICMP echo-response (type 0) and not an echo-request (type 8). Try the following:
ciscoasa# packet-tracer input inside icmp 10.0.1.14 8 0 209.165.200.2
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Confirm that you DONT HAVE this configuration on the firewall (DONT ISSUE THIS COMMAND)
sysopt noproxyarp outside
You can check if the above configuration is active with this command
show run sysopt
The point of this is to make sure that the ASA is answering to ARP requests from the upstream router that you are trying to PING.
- Jouni
Hmm,
Cant see any mention of the Proxy ARP related sysopts there.
Are you pinging a Router in front of ASA or where is the destination IP address you are pinging located?
- Jouni
I would rather have the route in this format
ip route 0.0.0.0 0.0.0.0 x.x.x.x
Where the "x.x.x.x" is the IP address of the ASA "outside" interface.
I am kind of wondering though why the default route on the "outside" of the ASA is pointing back towards ASA?
- Jouni
13 Replies 13
Jouni Forss
Seems you have issued a "packet-tracer" command
Can you copy/paste the whole output for us? And also the complete command issued?
Mask/Hide public IP addresses
- Jouni
Dear Jouni, Thanks for the reply to my concern. I am trying to ping from PC which has IP 10.0.0.14 to outside router interface. But i am not able to ping.
ciscoasa# packet-tracer input inside icmp 10.0.1.14 0 0 209.165.200.2
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   209.165.200.0   255.255.255.0   outside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group ICMPACL in interface inside
access-list ICMPACL extended permit icmp any any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect icmp
service-policy global_policy global
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
static (inside,outside) 209.165.200.254 10.0.1.14 netmask 255.255.255.255
  match ip inside host 10.0.1.14 outside any
    static translation to 209.165.200.254
    translate_hits = 2, untranslate_hits = 0
Static translate 10.0.1.14/0 to 209.165.200.254/0 using netmask 255.255.255.255
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 44, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: drop
Your Type/Code used for the ICMP in the "packet-tracer" dont correspond to sending and ICMP Echo
Use this command instead
ICMP Echo is Type 8 and Code 0, therefore we use "8 0" in the command.
- Jouni
Yes! It gives the allow result. But I dont know why I am not able to ping from the PC 10.0.1.14 to 209.165.200.2
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
    translate_hits = 3, untranslate_hits = 0
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 65, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
ciscoasa#
show run sysopt
- Jouni
ciscoasa#  show run sysopt
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
sysopt connection permit-vpn
no sysopt connection reclassify-vpn
ciscoasa#
Hmm,
- Jouni
It is a router conncted to the outside interface, I have properly configured the routing.
in router I have
ip route 0.0.0.0 0.0.0.0 f0/0 (Where f0/0 is connected to Firewall Outside)
- Jouni
Though I will have to say,
If you are NATing the LAN host to an IP address that is part of the link network between the ASA and the Router then even without a route on the router towards ASA, there should be no problem with routing/connectivity.
If the LAN hosts NAT IP Address is part of the connected network between the ASA and the Router then I would suggesting attempting the ICMP from the host to the router and also from the router to the host and checking on the router with command "show ip arp" if you can see the LAN host NAT IP address in the ARP table.
- Jouni
Dear,
I am able to ping the outside Router IP in ASA Version 8.4. I just tried it, the configuration is same as I have done in 8.0.
I will try today after going home for 8.0.2 again.
I will share the result, I will provide the complete Configuration and the topology diagram with you today evening 9pm GMT+3.
Hope we will resolve this issue.
engineer_msu
Dear Jouni,
It is working now, Rest of the configuration is same but I corrected the ICMP-INSPECT configuration and it is working now, below is the detailed configuration:
Router-1:
int f0/0
ip add 10.0.0.2 255.255.255.0
int f0/1
ip add 192.168.1.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.0.0.1 (Pointing towards Firewall)
Router-2:
int f0/0
ip add 172.16.1.2 255.255.255.0
ip route 192.168.1.0 255.255.255.0 172.16.1.1
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ASA:
interface e0/0
ip address 10.0.0.1 255.255.255.0
nameif inside
security-level 100
interface e0/1
ip address 172.16.1.1 255.255.255.0
nameif outside
security-level 0
route inside 192.168.1.0 255.255.255.0 10.0.0.2
route outside 0.0.0.0 0.0.0.0 172.16.0.2
------ Above is the basic configuration to be done in ASA ----------
To allow ICMP:
1. NAT is required if the outside IP is from the public IP Range (Ex: 209.165.200.0/24) for private IP NAT is not required.
2. NAT is not required if the NAT Control is not enabled in Firewall.
3. NAT is required if NAT Control is enabled in firewall even if the outside ip is private IP.
4. No need of ACL as by default the traffic is allowed from Higher Security Level to Lower Security Level (In our case Inside-100 to Outside-0)
5. Just Configure ICMP Inspect to allow ping in our case:
ASA(config)# class-map icmp-class
ASA(config-cmap)# match default-inspection-traffic
ASA(config-cmap)# exit
ASA(config)# policy-map icmp_policy
ASA(config-pmap)# class icmp-class
ASA(config-pmap-c)# inspect icmp
ASA(config-pmap-c)# exit
ASA(config)# service-policy icmp_policy interface outside
To enable ICMP inspection for all interfaces, use the global parameter in place of interface outside.
