Netflow problem with transparent ASA.
Dikkia
Hi all,
i'm facing a weird problem with asa5520x  (Version 9.6(4)10 ) in TRANSPARENT mode and Netlow collector (manage engine ).
I had to move the configuration of my transparent firewall from vlan mode  to subinterface with  portchannel.
Since then i receive no flow for the subinterface and/or etherchannel interface ( i receive flows for phisical port insted )
i wrote to manageengine and they say there is no particular conf on their software...and i should be able to see all the traffic if the ASA is correctly configured.
ASA is sending flows for other interface ( phisical and for the management )so  everithing is ok from the configuration point of view.
Manageengine said  that if i don't see the subinterface traffic...it means  ASA do not send flows for that specific traffic.
As far as i know..asa Netflow is supported by ASA in transparent mode....but i could be wrong.
any suggestion about this issue?
the asa conf is quite straighford....
flow-export destination MANAGEMENT 10.74.2.214 9996
flow-export template timeout-rate 1
flow-export delay flow-create 60
flow-export active refresh-interval 2
interface GigabitEthernet0/2
 description to cus-st0 Gi1/0/30
 channel-group 1 mode active
 no nameif
 no security-level
interface GigabitEthernet0/3
 description to cus-st0 Gi2/0/30
 no nameif
 no security-level
interface GigabitEthernet0/4
 description to cus-st0 Gi1/0/32
 channel-group 2 mode active
 no nameif
 no security-level
interface GigabitEthernet0/5
 description to cus-st0 Gi2/0/32
 no nameif
 no security-level
interface Management0/0
 management-only
 nameif MANAGEMENT
 security-level 50
 ip address 10.74.32.10 255.255.248.0 standby 10.74.32.11
interface BVI2
 ip address 10.48.92.189 255.255.255.240
interface Port-channel1
 nameif Inside-PortChannel
 bridge-group 2
 security-level 100
interface Port-channel1.70
 vlan 70
 nameif Inside-Lan
 bridge-group 2
 security-level 100
interface Port-channel2
 lacp max-bundle 8
 nameif Outside-PortChannel
 bridge-group 2
 security-level 0
interface Port-channel2.960
 vlan 960
 nameif Outside-Voda
 bridge-group 2
 security-level 0
class-map global-class
 match access-list global_mpc
class-map BGP_peering
 match any
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  no tcp-inspection
policy-map global_policy
 description regola per peering BGP
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
 class global-class
  flow-export event-type all destination 10.74.2.214
 class BGP_peering
  set connection random-sequence-number disable
service-policy global_policy global
0 Replies 0
