New Guest Network will not PAT to outside interface for overload
dan hale
Level 3
Level 3
Hello all, I just created a new interface on my firewall for Guest traffic but, I cant seem to PAT using the outside interface. Our firewall is a Cisco ASA 5512 running version 9.1. I'm stringing with the new NAT's.
We have an outside, DMZ, inside, and now a guest interface. When I try to add the this command I get the following:
ERROR: Address 192.168.1.1 overlaps with outside interface address.
ERROR: NAT Policy is not downloaded
Below is my interfaces and important info:
GigabitEthernet0/0       outside                192.168.1.1   255.255.255.252 CONFIG
GigabitEthernet0/1       inside                 192.168.254.1   255.255.255.0   CONFIG
GigabitEthernet0/2       dmz                    192.168.50.0   255.255.255.248 CONFIG
GigabitEthernet0/3       guest                  172.16.0.1      255.255.254.0   CONFIG
Here is the current PAT for my inside network that works:
object network obj_any
 nat (inside,outside) dynamic interface
Do I need to change my above nat to be more specific for the object network? I only have a /30 from my ISP for my outside and a /29 allocated for my DMZ servers.
I did try to remove the above nat and I added the following:
 object network OBJ-192.168.20.0-24
 description (my real inside address scheme)
 subnet 192.168.20.0 255.255.255.0
 nat (inside,outside) dynamic 192.168.1.1
Still got this same error (ERROR: Address 192.168.1.1 overlaps with outside interface address.
ERROR: NAT Policy is not downloaded)
Cant I not PAT both my inside and new guest networks to the same outside interface?
My outside and dmz subnets I have sanitized and are not the real routable subnets.
Dan
Don't think you can specify the IP address of the interface in a NAT statement, you have to use the "interface" keyword.
You should be able to do the following:
object network INSIDE-NETWORK
 subnet 192.168.254.0 255.255.255.0
object network GUEST-NETWORK
 subnet 172.16.0.0 255.255.254.0
 nat (guest,outside) dynamic interface
or you could:
 nat (any,outside) dynamic interface
