Ngfw 2130 as transparent fw using cli or fdm
adeebtaqui
Level 4
Level 4
We want to configure our newly purchased 2130 firewalls as inline firewall in transparent mode between internal core
and core switches in remote sites sharing same network subnet vlans. Kindly advise is transparent mode configurable directly on FW cli or fdm webui.
There is no new purchased FMC available.
For the transparent operation (I would prefer inline interfaces over transparent mode, but that doesn't change the management-requirements) you need to have the FMC. You can't configure that in FDM or via CLI.
Even cli cannot be used for configuration of transparent mode
Why is this not possible
The whole system was designed to be configured through one of the GUIs that are available (or an API). The CLI is mainly for Day-0 setup and troubleshooting. Cisco will likely never change this.
