ORACLE with PIX HELP
j.hato
Level 3
Level 3
I have an oracle server running vers 8i on inside network. Have been NAT-ed and have access-list permit all the tcp and udp connection to the server when access from outside. Here the error message from client access from outside:
oracle error con 440
unable to make connection oracle - 12514 tns.couldn't resolve service name
the menu was not connectable with oracle. a menu is ended
Many Thanks for HELP
HATO
marcreiter
Community Member
Oracle 8 uses dynamic ports in its connections. While it starts on (?1531?) it negotiatats a new port about every 6-20 packets. This will result in the above msg if you do not have all ports open.
Marc
Not an expert after 20 years.
sateeshk
Community Member
hi
For testing purpose Pls try to disable NAT in firewall..and try to access the server from outside.
As per ur info u said that all ports r open diffnetly it should work.but still its not working means problem with NATTING.
Regads
Sateesh kumar.k
alan
Visitor
PIX uses a default fixup syntax to handle the SQLnet connections. If you have moved the TNSlistner to a non-standard port (other than tcp 1521) PIX will not track the dynamically established sessions-- It watches TYCP 1521 to determine where the next dynamic port was negotiated by Oracle
