Packet capture on outside help
Andy White
Level 7
Level 7
I have a webserver on the DMZ and I want to capture all source traffic going to it's public IP.  I have used the ASDM packet capture before, but can't seem to get this traffic to show up.
My webserver is on (example) 80.170.156.86 (Outside) and translates to 172.32.1.3 (DMZ1)
I did this, but the output is empty.
! outside
! Apply ingress  capture on the outside interface.
capture asdm_cap_ingress match udp  0.0.0.0 0.0.0.0 80.170.156.86 255.255.255.255
capture asdm_cap_ingress packet-length 1522 buffer 524288
capture asdm_cap_ingress interface outside
! DMZ1
! Apply egress  capture on the DMZ1 interface.
capture asdm_cap_egress match udp  172.32.1.3 255.255.255.255 0.0.0.0 0.0.0.0
capture asdm_cap_egress packet-length 1522 buffer 524288
capture asdm_cap_egress interface DMZ
Any ideas?
Hi White.
Yeah... For the traffic initiated from outside.... You can try the below one and see.... If this doesn't give the desired result.... we can try with other options....
access-list out_to_dmz permit udp any host <80.x.x.x>
capture dmztoout interface outside access-list out_to_dmz buffer 524288 packet-length 1522
But for this some traffic needs to be going thru for that server.
Karthik
6 Replies 6
nkarthikeyan
Level 11
Level 11
Can you try like this??
access-list dmz_to_out permit udp host 172.32.1.3 any
capture dmztoout interface dmz1 access-list dmz_to_out buffer 524288 packet-length 1522
You can do vice versa for the inbound towards server
Karthik
I am particularly interested in what is coming it from the outside interface to this server, is this ingress to the outside interface?.
What public IPs are connecting to this server?
Hi White.
Karthik
Thanks, all working plus I've imported into wireshark.
Other than a packet capture to "see what is happeing" do you use "sh conn"?
Hi White,
Sh conn will give you the connection details along with flags and flow.
Sh local-host to display the network states of the local host....
Karthik
Do you add any filters to those commands as there is loads of data showing?
