Packet Tracer (Implicit Deny) issue
Kemal Zuko
I am trying to do a simple packet tracer  on my ASA and this is what I am getting
ASA#       packet-tracer input DMZ tcp 10.250.0.5 2234 10.250.0.6 22 xml
<Phase>
<id>1</id>
<type>ROUTE-LOOKUP</type>
<subtype>input</subtype>
<result>ALLOW</result>
<config>
</config>
<extra>
in   10.250.0.4      255.255.255.252 DMZ
</extra>
</Phase>
<Phase>
<id>2</id>
<type>ACCESS-LIST</type>
<subtype></subtype>
<result>DROP</result>
<config>
Implicit Rule
</config>
<extra>
</extra>
</Phase>
<result>
<input-interface>DMZ</input-interface>
<input-status>up</input-status>
<input-line-status>up</input-line-status>
<output-interface>DMZ</output-interface>
<output-status>up</output-status>
<output-line-status>up</output-line-status>
<action>drop</action>
<drop-reason>(acl-drop) Flow is denied by configured rule</drop-reason>
</result>
ASA#
The 10.250.0.6 deve is a router directly connected to the DMZ interface 10.250.0.5
However I am getting the reason for droped packet as (Implicit Rule) which I can see is only on the global interface.
I am permiting ip any any on that same interface as well.
How can I make this work?
The reson for this is I need my ASA to authenticate with TACACS server which is behind the 10.250.0.6 router
44 Replies 44
Go ahead and change it back to (DMZ). Can you enable debug for TACACS and post some of the debug?
Kemal Zuko
you mean to enable tacacs debug on the ASA?
here is what I see
%ASA-4-409023: Attempting AAA Fallback method LOCAL for Authentication request for user kzuko : Auth-server group BiHTac unreachable
%ASA-6-113015: AAA user authentication Rejected : reason = Invalid password : local database : user = kzuko
%ASA-6-611102: User authentication failed: Uname: kzuko
%ASA-6-315011: SSH session from 10.250.0.6 on interface DMZ for user "kzuko" disconnected by SSH server, reason: "Internal error" (0x00)
%ASA-6-302014: Teardown TCP connection 61690 for DMZ:10.250.0.6/54569 to identity:10.250.0.5/22 duration 0:00:07 bytes 1347 TCP FINs
Sorry Wrong log
here is the debug
%ASA-6-302013: Built outbound TCP connection 61851 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/31091 (10.250.0.1/31091)
%ASA-6-110003: Routing failed to locate next hop for TCP from identity:10.250.0.1/31091 to inside:10.250.100.142/49
mk_pkt - type: 0x2, session_id: 315
mkpkt - authorize user: bihadmin
cmd=no
cmd-arg=logging cmd-arg=console  Tacacs packet sent
%ASA-6-302014: Teardown TCP connection 61851 for inside:10.250.100.142/49 to identity:10.250.0.1/31091 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 315, seq no:1
%ASA-6-302013: Built outbound TCP connection 61852 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/52801 (10.250.0.1/52801)
TACACS Request timed out
TACACS Session finished. Session id: 315, seq no: 1
mk_pkt - type: 0x2, session_id: 316
cmd=no
%ASA-6-302014: Teardown TCP connection 61852 for inside:10.250.100.142/49 to identity:10.250.0.1/52801 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 316, seq no:1
%ASA-6-302013: Built outbound TCP connection 61853 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/28448 (10.250.0.1/28448)
TACACS Session finished. Session id: 316, seq no: 1
mk_pkt - type: 0x2, session_id: 317
cmd=no
cmd-arg=logging %ASA-6-302014: Teardown TCP connection 61853 for inside:10.250.100.142/49 to identity:10.250.0.1/28448 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 317, seq no:1
%ASA-2-113022: AAA Marking TACACS+ server 10.250.100.142 in aaa-server group BiHTac as FAILED
BIHASA(config)# TACACS Request timed out
TACACS Session finished. Session id: 317, seq no: 1
Big help, thanks.
Can you post another show route?
ASA(config)# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 75.132.0.1 to network 0.0.0.0
D    192.168.250.0 255.255.255.248 [90/28416] via 10.250.0.2, 38:50:54, inside
D    10.250.100.128 255.255.255.128 [90/28416] via 10.250.0.6, 38:50:44, DMZ
D    10.250.100.0 255.255.255.128 [90/28416] via 10.250.0.2, 38:50:54, inside
D    10.250.1.1 255.255.255.255 [90/130816] via 10.250.0.6, 38:50:44, DMZ
C    10.250.0.0 255.255.255.252 is directly connected, inside
C    10.250.0.4 255.255.255.252 is directly connected, DMZ
C    75.132.0.0 255.255.192.0 is directly connected, outside
d*   0.0.0.0 0.0.0.0 [1/0] via 75.132.0.1, outside
The routing looks good. In your TACACS server, what IP is configured as the host? The ASA's DMZ address?
Can we try and put a host specific route in for the TACACS server?
route DMZ 10.250.100.142 255.255.255.255 10.250.0.6
Then check the debug log again.
Ok did that but still nothing
I am also not seeng much in the debug
sh debug  tacacs
%ASA-4-409023: Attempting AAA Fallback method LOCAL for Authorization request for user bihadmin : Auth-server group BiHTac unreachable
debug tacacs session
ASA(config)# %ASA-7-111009: User 'bihadmin' executed cmd: show debug tacacs
I got debug tacacs and debug tacacs session running on logging console debugging
ok I have noticed that these error loggs come in very late. I got this error log below 5 min later
%ASA-7-609001: Built local-host inside:10.250.100.142
%ASA-6-302013: Built outbound TCP connection 63066 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/6622 (10.250.0.1/6622)
%ASA-6-110003: Routing failed to locate next hop for TCP from identity:10.250.0.1/6622 to inside:10.250.100.142/49
mk_pkt - type: 0x2, session_id: 332
cmd=show
cmd-arg=debug cmd-arg=tacacs  Tacacs packet sent
%ASA-6-302014: Teardown TCP connection 63066 for inside:10.250.100.142/49 to identity:10.250.0.1/6622 duration 0:00:00 bytes 0 No valid adjacency
%ASA-7-609002: Teardown local-host inside:10.250.100.142 duration 0:00:00
Sending TACACS Authorization message. Session id: 332, seq no:1
%ASA-6-302013: Built outbound TCP connection 63067 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/46116 (10.250.0.1/46116)
TACACS Session finished. Session id: 332, seq no: 1
mk_pkt - type: 0x2, session_id: 333
cmd=show
cmd-arg=debug %ASA-6-302014: Teardown TCP connection 63067 for inside:10.250.100.142/49 to identity:10.250.0.1/46116 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 333, seq no:1
%ASA-6-302013: Built outbound TCP connection 63068 for inside:10.250.100.142/49 (10.250.100.142/49) to identity:10.250.0.1/47263 (10.250.0.1/47263)
TACACS Session finished. Session id: 333, seq no: 1
mk_pkt - type: 0x2, session_id: 334
cmd=show
cmd-arg=debug %ASA-6-302014: Teardown TCP connection 63068 for inside:10.250.100.142/49 to identity:10.250.0.1/47263 duration 0:00:00 bytes 0 No valid adjacency
Sending TACACS Authorization message. Session id: 334, seq no:1
BIHASA(config)# TACACS Session finished. Session id: 334, seq no: 1
%ASA-6-305012: Teardown dynamic UDP translation from inside:10.250.100.4/52561 to outside:75.1.1.1/52561 duration 0:00:31
I have also noticred this
It mentions "inside" the 10.250.100.142 is behind the DMZ
ok... for some reason it didint take my last commands when I was putting it back on to the DMZ
Lets try the debug again
Nothing no debug loggs this time when I try to connect
sometimes I see this
mk_pkt - type: 0x2, session_id: 370
cmd=show
cmd-arg=access-list cmd-arg=DMZ_access_in cmd-arg=brief  Tacacs packet sent
Sending TACACS Authorization message. Session id: 370, seq no:1
TACACS Request Timed out. Session id: 370, seq no:1
mk_pkt - type: 0x2, session_id: 371
cmd=show
Sending TACACS Authorization message. Session id: 371, seq no:1
TACACS Session finished. Session id: 370, seq no: 1
TACACS Request Timed out. Session id: 371, seq no:1
mk_pkt - type: 0x2, session_id: 372
cmd=show
Sending TACACS Authorization message. Session id: 372, seq no:1
TACACS Session finished. Session id: 371, seq no: 1
TACACS Request Timed out. Session id: 372, seq no:1
TACACS Session finished. Session id: 372, seq no: 1
mk_pkt - type: 0x2, session_id: 373
cmd=show
Sending TACACS Authorization message. Session id: 373, seq no:1
TACACS Request Timed out. Session id: 373, seq no:1
mk_pkt - type: 0x2, session_id: 374
cmd=show
Sending TACACS Authorization message. Session id: 374, seq no:1
TACACS Session finished. Session id: 373, seq no: 1
TACACS Request Timed out. Session id: 374, seq no:1
mk_pkt - type: 0x2, session_id: 375
cmd=show
Sending TACACS Authorization message. Session id: 375, seq no:1
TACACS Session finished. Session id: 374, seq no: 1
TACACS Request Timed out. Session id: 375, seq no:1
TACACS Session finished. Session id: 375, seq no: 1
I saw that too and that's what made me think it could be a routing issue. Can you do another packet-tracer?
packet-tracer input DMZ udp 10.250.0.5 49 10.250.100.142 49 detail
